Best settings to use for rooftop surveying
I’m a complete noob and am wondering what is best for capture of roof 2d or 3D and how to process after. I know it’s a loaded question but I’m trying to see if pix4d will give me data my clients can use for rooftop surveys.
I use a mavic pro 2 and an inspire 2 with x5s camera.
Thanks in advance.
You can have a combination of the circular and the single grid mission for the image acquisition. For more information, I would suggest you to go through our support article on Types of mission / Which type of mission to choose.
To process the data, I would suggest to follow the steps explained in the below support article on Creating a Project.
I also found a video which might be useful to you.
Roof inspection with Pix4Dcapture
Thanks so much that helps.
Hi - I’m new to Pix4D and have a few questions related to roof inspections by drone:
What is the best mission to select for these?
What is the optimal height above a roof to set the mission at?
What Pix4D resources should I be focusing my attention on to become an expert in this field?
Thank you!
Hello @jake.m.swartz,
I would recommend you to go through the above post. I would also suggest you to go through the post created by @Veronica_Alonso on Liverpool Central Station roof inspection - Keith Wakeley - H&W Surveying and Consulting Ltd.
Thank you! I will check them out!
