Add most of Virtual Survey workflows and tools
Virtual Survey is an amazing software and a big competitor for Survey.
It has some great tools, I’ll list some here:
  1. Better offset tools (check the other software)
  2. Polyline/arc tool improved
    3. TIN surface tools
  • Swap/edit/delete triangle lines
  • Boundary
  • Voids
  • Build by Sections (check the sections tool in Virtual Survey)
  1. Drape by interval
  2. Points edit and interpolation
  3. Add external TIN surfaces
  4. Compare terrains
  5. Better Cut and Fill
  6. Survey point template marks with dxf text export
