Hi there,
Pix4D has omitted a section of the project comparing to what could be processed by dronedeploy.
Could someone help so that the top of section of the missing section can be processed?
Hi there,
Hi Leslie,
This section has not been processed because uncalibrated cameras are disabled for processing.
I recommend you this article to understand better the cause of this: Quality Report Help
You can try to get more calibrated cameras using these options:
Menu Process > Processing Options… > 1. Initial Processing > General
A last and painful solution would be to manually calibrate the uncalibrated camera.
Hope this will help you,
