I’m trying to get a surface area for a surface with complex curves and I’m uncertain if the area measure feature using polygons is calculating it correctly.
Think about trying to measure the surface area of a large bowl or dome. The polygon with cover the base circumference of the shape but I’m unclear as to whether or not the “3D area” number is calculating the actual 3d surface area of the complex curve, or simply the area of the relatively flat polygon.
Does anyone know how the measurement area is actually being calculated?
Hi @Daniele_Lecci , so essentially there’s no way to measure the surface area of a point cloud? I’ve found a few other softwares that do this easily and I’m surprised this isn’t a feature of Pix4D.
I passed it on to our product teams. Even though we cannot guarantee that a solution will be implemented, I can assure you that every piece of feedback is internally evaluated at Pix4D.
Additionally, I’ve moved this thread to the “PIX4Dsurvey Feature Request” section, where you and other Pix4D community members can vote for this request.
This would be great! Currently we create an TIN surface for this and then export it to Autodesk Civil 3D in order to get the area.
It would be amazing if Survey would give out the 3D-Area of an TIN or even better: when we could create reports with Survey.
