US Survey Feet in the Arbitrary Coordinate System Option!
Hi @Chris_Putnam , you do not have to import GCPs into PIX4Dmatic to change the coordinate reference system. Look at the “pen” icon, this lets you edit the CRS of the GCPs (even without there being any!) which will set the project CRS too (bottom left of the interface):
This is the window you get when hitting on the “edit” (aka little pen) button:
There is an * that mentions that this sets the project CRS too.
Hope this clarified the situation.
Thanks @Pierangelo_Rothenbuhler, I figured that out. However, I have been frustrated with the GCP import. In Mapper, I would find all of the points once the primary point cloud was generated and tag them. I would give them the same name as the GCPs in the csv. When I imported the CSV, it would ask me if I wanted to replace the current information with the information on file. That isn’t the case with Matic, which is unfortunate.
@Chris_Putnam I have an assumption on why you proceed like that, but I will still ask. Why does the standard workflow not work for you?
The steps would be something like:
  • Drag & drop (or select) the GCP file into the tie points table
  • Define the coordinate reference system
  • Define the column names (either manually, or by applying a template)
  • Import and view the GCPs in the tie point table and in the 3D view (as well as 2D view)
  • (optional) Mark BEFORE calibration, but the alignment will likely be less good, except if it’s an RTK project.
  • Run the calibration
  • (optional) Run AutoGCP marking from the menu bar. Note: this works only if you have known targets (cf https://support.pix4d.com/hc/en-us/articles/4402423894545-Automatic-target-detection-AutoGCP-algorithm)
  • Select a GCP in the tie point table or in the 3D view
  • Mark the GCP in the associated images, until all reprojections (the green crosses) are at the right spot in the images.
  • (optional) use the “Auto-mark” helper, if you do, still check that the marks are at the right place.
  • Once you marked all your GCPs. Run Reoptimization (and optionally chain other steps such as the densification, e.g. if it’s the end of the day and you’ll see the project the next day only anyway).
  • Verify the reprojection errors and the errors on the GCPs in the tie points table (order them by values in the errors columns by using the arrows next to the column name). Check that there is no error too large according to your specs.
Okay, that’s about it. Can you please highlight why your workflow is more adapted for you? and what’s the flaw in the one above? That will help us adjust if needed.
Thanks!
@Chris_Putnam just saw this other post: Manual Tie Points
Maybe your workflow is the same? The fact it is in arbitrary coordinates would explain why your workflow works better.
Your assumption is correct. But let’s go through the exercise to make it valuable to anyone who might be searching for an answer to this.
**Pointless (haha), because in an arbitrary coordinate system, they aren’t referenced.
**I define the arbitrary coordinate system first (which, as an aside would be nice as a template option)
You should add orange Home Depot bucket lids with Gorilla Tape crosses to the known targets list. :grin:
The rest of the steps are synonomous.
My issue is that, when the arbitrary coordinate system is used, all georeferencing goes away. I usually (in mapper):
  • Define the arbitrary coordinate system
  • Run step 1
    *Import GCP file into Global Mapper and convert it to international ft.
    *Export .csv control file in international ft.
  • Open Google Earth or Global Mapper and import the GCPs there to use as a visual reference to find the targets.
  • Locate and name the targets using the same nomenclature as the .csv control point file.
  • Import the GCPs, at which point Mapper asks me if I would like to replace the current values with those in the file. I replace the current values with those from the file.
  • Re-run step 1
  • Check error
  • Re-match / optimize or continue to steps 2 and 3.
  • Export
  • Open in Global Mapper as international ft
  • Convert to USft
  • Import original control file (in USft) as a final check before distribution
  • Export all deliverables in USft.
What would really be the gamechanger would be a process that allowed me to translate the arbitrary coordinate system to the “world.” In addition to the NEE or XYZ coordinates, there should be columns for Lat, Lon, Elevation where:
X=Lat
Y=Lon
Z=Elevation
That would solve alot. I would still like to have the option to replace the values by importing a new file. There have also been times when I have imported the wrong control file. In mapper, no big deal. I just had to import the correct file and replace the values. That would still be nice.
mhm, ok, I think I get your workflow. You process the project as if it was in a known CRS, there you mark the GCPs. That way you have the normal GCP marking workflow with cameras, GCPs, etc…at the right place. Once marked, you say it’s all in arbitrary, at which point you import the arbitrary GCP coordinates, which overwrite the automatically defined ones from the initial marking. Is that it?
In theory, you could do the same in PIX4Dmatic, except that I don’t think we overwrite existing values of GCPs when you reimport it. Also, changing the CRS in PIX4Dmatic removes any processing, so you would need to start from scratch. So checking whether we can be more flexible with the CRS change, as well as overwriting existing coordinates could be interesting.
Another idea. Would the site localization workflow be another alternative that provides a link from the arbitrary to a known crs? You would measure known points in the arbitrary CRS and in a known CRS, this allows you to create a transformation between the two coordinate systems, which you can import into PIX4Dmatic. These two articles may be interesting for you:
Haha! Let’s see what we can do.^^
Now more than ever. With rtk drones becoming the norm, it would be huge to use our own local USft systems.
Please make USft available for arbitrary and site calibrations!
Chris have you gotten aroud this?
I might be missing something, but you can set ftUS in the Arbitrary CRS definition:
Or were you looking for something else?
I’m referring to Mapper.
Oh right, sorry I got confused as both software were mentioned throughout the thread. Thanks for clarifying.
