Hello @thesundrones, If that is the case, it is for sure that the metadata they have in their raw images is not the same as normal rjpeg images which is causing the issue. However, if you are able to create grayscale images out of those thermal images, PIX4Dmapper should be able to process it. If you are using that camera, I would suggest you to follow the steps recommended by the user in the below post:
