Hello, I’m processing data from a DJI Mavic 3M. Under processing options I should be able to select the weather conditions, however this is always greyed out. What’s the reason please?
Are you sure you selected the multispectral images (.tiff), as this is not supported for RGB images (.jpg) ?
Yes, I always work with the multispectral images.
Please check if your drone has the latest firmware installed. You need to create a support ticket via Contact support if the problem persists and share the log files with the agent so they can troubleshoot your problem.
