I have produced reflectance maps using the Sentera 6X camera without calibration target images and am curious what the expected range of values should be for the outputs. Typically with calibration target images the expected range of values is 0 to 1 for a reflectance map. Without the calibration target images the outputs are different depending on the correction type selected. No correction = DN range 0-4096, Camera only = 0~100,000, camera and sun irradiance = 0~50. Is there an expected range of values for these correction types? Is there a way to find this in the index calculator?
Hi Joseph,
I saw you submitted a support ticket. I will reply there.
