Ray cloud uncalibrated camera
Hi Nathan,
The All Prior options forces the optimization the internal parameters (principal point, focal length, distortions) to stay close to the initial values.
This option can remedy bad calibration in case that:
  • The terrain is flat and there is no 3D information to facilitate the computation of the optimized camera parameters, which leads to ambiguity (multiple possible solutions).
  • The project is bent after processing.
  • The focal length is optimized far from the initial value, which also indicates ambiguity (example: the cameras are on the level of the model).
But apparently in your project it it did not help.
I am surprised to see that Aerial Grid causes this curvature.
I would suggest you this post as well:
Which file are you talking about?
My recommendation would be here to do several tests on step 1 to see what are the best processing option for you data set. (it is difficult to give a ready to make recipe in photogrammetry. Sorry about that).
Best
