Pixel stretching orthophoto
I have notice that I get pixel stretching around buildings, cars and trees when generating the orthophotos. The orthophotos look distorted on these areas. what would be the solution.
Hey Juan, it’s probably due to the way that the orthomosaic is generated. You can usually reduce blurring around objects by taking more pictures or edit the point cloud. Worst case you can use the orthomosaic editor to edit the ortho and use a planar image which is more crisp but is not geometrically accurate.
  • PF
