Pix4dCapture and Crtl+parrot
to use Pix4dCapture with anafi is necessary to install and use the plug in Crlt+parrot? then run Pix4dCapture?
I don’t get any parameter just connecting and nothing else
The Ctrl+ parrot isn’t required if you are using the iOS version of the Pix4Dcapture app. However, the android version of the Pix4Dcapture would require Ctrl+ parrot to connect to the drone.
Hello Kapil,
Yes actually I was referring to the use with android because until now using different android devices I don’t see any parameter in the Crtl + Parrot that actually should show.What could be wrong?
Best regards
The behavior you are describing can’t be replicated on our side and has not been reported to us so far. I would suggest you go through all the basic checks and troubleshooting steps as it will solve most of the issues that can be encountered if properly followed.
Also, make sure that you are using the Pix4Dcapture version 4.9.0, which support the latest Parrot Anafi Firmware(GroundSDK 1.2.1)
Hello, I am having the same issue. I am on a Pixel 4a, previously a Pixel 2. No success. Free flight app works fine but Ctrl+ will not recognize my drone. Is there any fix?
Hallo,
This issue stiil remain and doen’t matter which android device I use
All suggeted by Kapil won’t solve the issue, everything on the anafi is up to date
Question: it is still necessary to use Ctrl+Parrot with Pix4dcapture on Anafi? or don’t need it anymore?
As I told you on the Parrot Pilot forum… the Ctrl+Parrot app should no longer be used on Android with Anafi to start Pix4Dcapture ;o)
… a little search on this forum should confirm this… as well as a deeper documented answer from the community manager…should clarify this point !
