Pix4d Mapper large error on Check Point
I’m having strange troubles processing a projects with GCPs. If I use all the known points as GCPs, i’ll usually get good accuracy on those points.
However, if I set some of those as check points, there is an error on z coordinate, around 20 cm (CP t2).
I captured this project from height of 50m and 80% overlap.
Below is geolocation lines from processing report and a link to the entire report and log file.
part_report.pdf (1.9 MB)
