phantom 4 RTK correct camera parameters
What DJI phantom 4 RTK camera parameters should i use s the sensor width correct or should i update it. In another software im using sensor width as 13.2
Hi Siim,
The best would be to use the camera parameters that are automatically detected by the software since this camera is in Pix4D camera’s database which means that it has been calibrated for an optimal usage.
So basically, do not change anything.
Which-Cameras-exist-in-Pix4Dmapper-Database-and-which-Parameters-are-used
How-to-use-the-Editing-Camera-Model-Options
Hope this will help,
