Is it possible to process a collection of images that are non-contiguous?
Do the pictures have EXIF attached to them?
I import the image position and orientation from a text file. We use a manned aircraft and might collect a dozen photos in one location and then a few more in another location. I’m wondering if there is a way to process them all together or if they have to be separate projects or sub-projects.
@ Thaddeus,
You can add all the images even if they are in another location. Just click again add images and select the images you need.
Did you try it?
Max.
