Has anyone had issues merging 2 or more projects with the vertical misalignment where the projects overlap.
the coordinate system is the same in all the projects, as are camera settings, this was flown with an Ebee Plus RTK so the geo-tagged images should produce ray clouds that match when merged without the need for manual tie points
Hi Russel,
Could you please share more information about the project?
For example:
- screenshots of the problematic area
- measurement of the vertical displacement
- quality reports of the subprojects before merging
- quality report of the project after merging
The files might be rather large, so you might need to use a file sharing service such as WeTransfer, Google Drive or Dropbox and share the link here. This will help understand the problem. Thanks!
