Hello, I have to map an offshore platform, then instead of the ground surrounding the structure there is water. Can the water cause any problem like the sky when creating the orthophoto?
| Topic | Replies | Views | Activity | |
| Problemas para hacer ortomosaico con imágenes tomadas en la costa | 1 | 309 | August 30, 2021 | |
| Reflective Water in Orthomosaic | 5 | 2507 | April 2, 2020 | |
| How can I generate the surface of a lake in PIX4D? | 7 | 1871 | April 26, 2018 | |
| level of sea bottom instead of water level | 1 | 319 | February 23, 2020 | |
| Orthophoto cutting problem on sea/water | 15 | 509 | June 25, 2024 |
We - and our partners - use cookies to deliver our services. By using our website, you agree to the use of cookies as described in our Cookie Policy
