Lots of uncalibrated cameras in a dense vegetation map project
@kg1, You are right about the wind. However, for photogrammetry, we generally recommend flying high as it is easier to detect visual similarities between overlapping images in vegetation areas. If you fly high there is more variation and even if the leaves moved due to some wind, that will not be visible too much (will cover less pixels).
