is a Zenmuse X7 worth it?
Hi. I work for a survey firm and use pix4D mapper to create topographic maps and detailed surveys of property. I current collect all my images with a DJI Zemuse X4s and am happy with my results. Im always searching for a better solution with faster results and higher accuracy. Im considering purchasing the Zenmuse X7 - DJI DL-S 16mm F2.8 ND ASPH gimbal and lens. I wanted to see if there is anyone out there who is currently using this setup and what kind of results you are seeing before I make the purchase.
Any info you can provide would be greatly appreciated.
