Importing images with transparency.
Hi!. I already submit a request about this but i would like to know the opinion of other people also.
I`m making an orthomosaic of a facade and I would like to know if there is any way to import images to the proyect wich I had previusly edited on photoshop to delete the parts of the pictures that wasn’t relevant for me. I start trying this method in order to optimize the processing time and i get great results but i still having some troubles.
Problem is that jpeg does not support transparency and it fills the empty parts with white color, so when I procces de densified point cloud and the 3d texture mesh i get this nasty white parts arround the facade wich i have to remove editing de point cloud in order to get the ortho as i want.
In addition, i want to export the 3d mesh , wich is not editable in pix4d, so then i have to remove again this white parts manually on the other software.
I try to import the images as .tiff saving with transparency but again the software fills the empty parts with white.
Sorry for my English but i m from Spain.
Thanks for your time
ther is the link to the request, as i can’t add images here:
https://support.pix4d.com/hc/en-us/articles/hc/en-us/requests/10960
Hi David,
You should not preprocess your images in Photoshop. Pix4Dmapper gives you the tools to process part of your area. You have the following 2 options:
Draw a Processing Area: https://support.pix4d.com/hc/en-us/articles/202560589-How-to-Draw-a-Point-Cloud-Densification-Area-with-the-rayCloud
Annotate the images: https://support.pix4d.com/hc/en-us/articles/202560549-How-to-Annotate-Images-with-the-rayCloud
One of these options should work for you!
