HOW TO REMOVE SHADOWS?
Hi @Dronesurvey,
Could you be more specific?
Adding a screenshot and a quality report would greatly help into understanding your problem.
I would also recommend you checking the following articles with detailed step-by-step instructions :
- Distortions and Artifacts in the Orthomosaic (using Mosaic Editor)
- How to correct Building Artifacts in the DSM and Orthomosaic (changing processing options, adding surfaces, using Mosaic Editor).
- How to correct Building Artifacts in the DSM and Orthomosaic with the rayCloud (adding surfaces).
- How to improve the Visual Aspect of Buildings in the Orthomosaic with the Mosaic Editor.
Looking forward for your reply.
Best
I would recommend you to add surfaces to improve those artifacts and use the mosaic editor. This is described in the articles sent above.
This absolutely not recommended to modify images using Photoshop it erases core information needed for the processing.
The best would be to fly when the sun is at the high point in order to avoid to have shadows in your projects.
Best
Well the best you can do once the images are taken and processed is to clean the point cloud, add surfaces, use the mosaic editor.
If you find a better solution we will be glad to hear about it.
Let us know.
Best
THANKS
