Grid DSM
How are grid DSM points generated? Are the points absolute or are they created by algorithms that look at the block of points around them?
Hi @joejohnbennett ,
With the Grid DSM, you can select a desired vector file format to export the digital surface model (DSM) as a point cloud or grid.
The Grid Spacing [cm] defines the distance between two 3D points in the Grid DSM and is given in centimeters. For example: a grid spacing of 100 centimeters will generate one 3D point every 100 centimeters. The default value is 100 centimeters. One DSM with the selected spacing is generated in addition to a DSM generated using the resolution selected in the DSM and Orthomosaic tab.
For more:
