gpu use on recent updates?
I’m doing quite a bit of analysis at the moment. The process of importing, stitching, etc seems to be taking longer. I also see the GPU utilization is much less than what I remember a year ago, although it could easily be just my imagination.
So, to appease my curiosity… Did the recent updates change algorithms to use the GPU less?
-Mike
Hi Mike,
We did not change our algorithms to utilize fewer GPUs; on the contrary, we used more.
It is hard to tell from feelings alone.
If you have an old project, you can check the processing time from the logs and compare it to the same images being processed in the latest version.
