gimbal shaking
I use the IOS version of pix4d capture on anafi parrot.
I have noticed that the gimbal of the drone has slight tremors during the flight. the same issue does not occur in flight with FreeFlight 6.
Do you know why this is happening?
Thank you.
Hello there, We haven’t heard about this issue with other users, so I would suggest you to updating all the hardware from the drone and go through the troubleshooting steps to see if that helps.
