Exporting an existing layer to a new project
Can you answer me with the procedure, in which way I can select an existing layer in the current project, export it to the desktop and subsequently import it into a new project?
For example, if I map wheat with Mavic 3 Multispectral in different phases, before fertilizer application and after fertilizer fertilization, it would be professional to report the entire history in one PDF document so that the differences are clearer. We are not able to do this if all previous layers are not in one project?
Thanx…
To manage and report the entire history of your wheat mapping in PIX4Dfields, you can follow these steps to export an existing layer and import it into a new project:
Exporting a Layer:
  1. Select the Layer to Export:
  • Open your current project in PIX4Dfields.
  • Click on the Export tab at the top right corner of the dashboard.
  • Select the feature layer you want to export.
  • Choose a destination folder on your desktop and click Select Folder Windows or Open macOS .
Importing the Layer into a New Project:
  1. Create a New Project:
  • On the dashboard, click + New Project or the “plus” symbol at the bottom right corner of the window.
  • Click NEW PROJECT to create a new empty project.
  • Rename the project by clicking the pen symbol beside the default project name.
  1. Import the Exported Layer:
  • Click the Import icon.
  • To import the exported layer, select the appropriate option e.g., IMPORT GEOTIFF if the layer was exported as a GeoTIFF file .
  • Navigate to the folder where you saved the exported layer and select it.
  • Click Open to import the layer into the new project.
Creating a PDF Report:
  1. Generate the PDF Report:
  • Once all layers are imported into the new project, go to the Export button in the top bar.
  • In the Export panel, select the export type as PDF report .
  • Include all the outputs layers you want to display in the PDF report.
  • Click Export to generate the PDF report.
For more detailed instructions, you can refer to the How to import and export layers - PIX4Dfields
Thank you so much for answer…
Regards
