As usual, I was separately processing only the multispectral images (.tif) from the Mavic 3 Multispectral in a new project, when I noticed that the processing was unable to go beyond Initial Processing (Total 2/8) and sending the following error messages:
[2024.06.09 17:51:59][ 13%RAM][ 75%CPU][Info]: Remove tracks error 807 removed from 333452
[2024.06.09 17:53:03][ 13%RAM][ 69%CPU][Info]: After first: error: 0.702834 nrProjections: 1328295 nrTracks: 330194 trackSize: 330194 s0(0) s1(0) s2(165723) s3(57312) s4(31103) s5(76056)
[2024.06.09 17:55:28][ 13%RAM][ 49%CPU][Info]: After second: error: 0.363318 nrProjections: 1280241 nrTracks: 306856 trackSize: 306856 s0(0) s1(0) s2(143686) s3(56058) s4(31063) s5(76049)
[2024.06.09 17:56:49][ 13%RAM][ 65%CPU][Info]: Remove tracks error 838 removed from 333452
[2024.06.09 17:57:34][ 13%RAM][ 70%CPU][Info]: After first: error: 0.866936 nrProjections: 1324300 nrTracks: 328282 trackSize: 328282 s0(0) s1(0) s2(164025) s3(57180) s4(31057) s5(76020)
[2024.06.09 18:01:27][ 13%RAM][ 48%CPU][Info]: After second: error: 0.321735 nrProjections: 1277694 nrTracks: 305626 trackSize: 305626 s0(0) s1(0) s2(142618) s3(55954) s4(31036) s5(76018)
[2024.06.09 18:02:03][ 13%RAM][ 56%CPU][Info]: Remove tracks error 847 removed from 333452
[2024.06.09 18:02:14][ 13%RAM][ 67%CPU][Info]: After first: error: 5.41131e+015 nrProjections: 1334092 nrTracks: 330506 trackSize: 330506 s0(0) s1(0) s2(165017) s3(57693) s4(31247) s5(76549)
[2024.06.09 18:03:54][ 13%RAM][ 45%CPU][Info]: After second: error: 5.63913 nrProjections: 1059684 nrTracks: 259538 trackSize: 259538 s0(0) s1(0) s2(117490) s3(49342) s4(27702) s5(65004)
What is happening ?
