Display of Sο2 error when marking points on images
Why is there an option in Pix4Dmapper to display the error of imprecise pointing marks on images, but nowhere to be found in survey? This helps users to judge whether a point is measured correctly.
I am talking about this error.
Hi @mwywial
These values cannot be shown because not all the projects provide this information (for example, if you import a point cloud directly, you won’t have all the information about the images and calibration).
However, I have forwarded the request to the product team to see if this would be possible to add if for PIX4Dmatic and PIX4Dmapper projects opened in PIX4Dsurvey.
Daniele
Hi @Daniele_Lecci ,
It is known that this is to apply to projects that are imported from Pix4Dmapper or Pix4Dmatic.
Thanks and hope for a quick modification :wink:
Yes, I wanted to refer to PIX4Dmatic and PIX4Dmapper. Thank you for the correction :sweat_smile:.
I forwarded the request to the product team. I see there are already two votes for this request :bulb: .
Daniele
Hello!
Is there any work in progress to add the functionality described above?
Is the Pix4Dsurvey IT team working on adding this important (in terms of achieving the highest accuracy) feature?
