Display of known GPS coordinates
It is good to know the GPS coordinates on the generated map.
Do you provide the ability to map the GPS coordinates sent by people in the field?
Hi Kim,
The only tool that we provide is the GPS tool, which shows the coordinates of an object and can be optionally saved as a marker in the map. More information here: How to use tools.
Teodora
If the rescuer puts in the disaster site tells the GPS information of the found object, I want to share it on the newly created map.
I expect to have such a feature.
Hi Kim,
Adding this feature is currently not on the roadmap. However, your suggestion will have more weight if you share it on our Community and collect more votes from other users.
Here is how you can do this:
  1. Go to the category Feature Request/Suggestions.
  2. Log in or create an account, if you don’t have a Pix4D account yet.
  3. Look for the feature you are interested in. Someone else might have already asked for it. If such request doesn’t exist, create it as a new topic.
  4. Vote for it.
  5. Done, your vote is counted!
  6. You can manage, follow-up or even remove your vote(s) if you change your mind.
Teodora
Thank you for the reply.
I’m very interested in using Pix4dreact.
We are looking into any problems in the field.
I hope there are many developments.
