Dear PIX4Ddev team, could you add a way to visually distinguish control points (GCPs used for georeferencing) from checkpoints in the GCP/MTP editor?
Right now both are shown in the same green, and the only differentiation is the pink highlight on the currently selected point. When working on large sites with many GCPs (I typically use 4-5 as control points and mark the rest as checkpoints), it’s hard to get a quick visual read on which points are set as which. A distinct color per category (control point vs. checkpoint) would make it much easier to verify the setup at a glance, especially before processing.
I’ve seen this handled more clearly in other photogrammetry suites, where the two categories get separate default colors. Happy to leave the actual color choice up to you.
Thanks as always for the continuous updates to PIX4Dmatic, they’ve made a real difference in our workflow.
One more question: how can I earn more votes for feature requests? All are gone meanwhile and don’t get refreshed? ![]()
@Rhea_Garratt @andrea.dotti @Pierangelo_Rothenbuhler could you please be so kind and take a look here, to speed things up? I guess this might be very helpful to other users, too…Thanks and hopefully see you guys in Munich. Cheers ![]()
