Cut or trim photograph
I Would like to ask if it is possible to cut or trim a section out of a photograph input (for instance, when an original photograph has sky), and use this phorograph as input for a project.
The problem was this, I made a double grid mission, and I took some photographs with a mavic pro to complement the double grid. In that moment I didn’t realize that the bar of the dji app was hidding a portion of the photograph, and now in the top of the photograph its has some sky and this is not recommend for pix4d. If I cut a portion of the photogropah I can trim the sky, however the photograph will loose the aspect.
Thanks,
Diego
A post was merged into an existing topic: Image Mask / Annotation and Affect on Processing
