This sounds similar to this other post: DTM removing hills peaks
Do you have the same issue? Can you post screenshots of your contour lines processing options? Maybe some examples of what the badly generated contour lines look like? Some quality report? More information would definitely help to investigate the issue.
Here is how you can export the point cloud: How to export the Point Cloud
