como corregir dataset y matching
hola, como puedo puedo corrregir problemas con dataset (esta en 31% de las imagenes ) y como corregir el matching
Hello @v-26442302, If you have a lot of uncalibrated images, then the issue might be something related to the image quality or overlap. Always make sure that you have good images overlap during image acquisition. I would recommend you to go through the below support articles.
