Changing DXF Contour Line Elevation Interval
I finished a project and outputted a DXF file with the default contour line spacing. Can I change the elevation interval and produce that DXF file without having to run the whole project all over again?
Hello Daniel,
You can do that. Just select your new contour line settings as usual  and go to:
If the DSM or DTM already exist, only the contour lines will be generated.
Regards.
