cannot create ogr layer for tie points
What’s this? I can’t export my tie points?
Log Report;
[Warning]: Warning w9020: GDAL error \<1\> Failed to create file .shp file.
[Warning]: Warning w9020: GDAL error \<4\> Failed to open Shapefile `C:/Program Files/Pix4Dmapper\bolaman\_gcp\_initial.shp'.
[Warning]:
[Error]: Cannot create OGR layer for tie points!
[Warning]: Warning w9020: GDAL error \<4\> Failed to open Shapefile `C:/Program Files/Pix4Dmapper\bolaman\_gcp\_computed.shp'.
[Warning]:
[Warning]: Warning w9020: GDAL error \<4\> Failed to open Shapefile `C:/Program Files/Pix4Dmapper\bolaman\_mtps.shp'.
[Warning]:
[Error]: Cannot create OGR output file C:/Program Files/Pix4Dmapper\bolaman\_gcp\_initial.dxf!
[Error]: Cannot create OGR output file C:/Program Files/Pix4Dmapper\bolaman\_gcp\_computed.dxf!
[Error]: Cannot create OGR output file C:/Program Files/Pix4Dmapper\bolaman\_mtps.dxf!
[Warning]: Warning w9020: GDAL error \<6\> dataset C:/Program Files/Pix4Dmapper\bolaman\_gcp\_initial.dgn does not support layer creation option SEED
[Warning]: Warning w9020: GDAL error \<6\> dataset C:/Program Files/Pix4Dmapper\bolaman\_gcp\_initial.dgn does not support layer creation option UOR\_PER\_SUB\_UNIT
[Warning]: Warning w9020: GDAL error \<4\> Unable to open `C:/Program Files/Pix4Dmapper/bolaman\_gcp\_initial.tmp\_seed' for read access.
[Warning]:
[Warning]: Warning w9020: GDAL error \<6\> dataset C:/Program Files/Pix4Dmapper\bolaman\_gcp\_computed.dgn does not support layer creation option SEED
[Warning]: Warning w9020: GDAL error \<6\> dataset C:/Program Files/Pix4Dmapper\bolaman\_gcp\_computed.dgn does not support layer creation option UOR\_PER\_SUB\_UNIT
[Warning]: Warning w9020: GDAL error \<4\> Unable to open `C:/Program Files/Pix4Dmapper/bolaman\_gcp\_computed.tmp\_seed' for read access.
[Warning]:
[Warning]: Warning w9020: GDAL error \<6\> dataset C:/Program Files/Pix4Dmapper\bolaman\_mtps.dgn does not support layer creation option SEED
[Warning]: Warning w9020: GDAL error \<6\> dataset C:/Program Files/Pix4Dmapper\bolaman\_mtps.dgn does not support layer creation option UOR\_PER\_SUB\_UNIT
[Warning]: Warning w9020: GDAL error \<4\> Unable to open `C:/Program Files/Pix4Dmapper/bolaman\_mtps.tmp\_seed' for read access.
[Warning]:
[Warning]: Warning w9020: GDAL error \<4\> Failed to create KML file C:/Program Files/Pix4Dmapper\bolaman\_gcp\_initial.kml.
[Error]: Cannot create OGR output file C:/Program Files/Pix4Dmapper\bolaman\_gcp\_initial.kml!
[Warning]: Warning w9020: GDAL error \<4\> Failed to create KML file C:/Program Files/Pix4Dmapper\bolaman\_gcp\_computed.kml.
[Error]: Cannot create OGR output file C:/Program Files/Pix4Dmapper\bolaman\_gcp\_computed.kml!
[Warning]: Warning w9020: GDAL error \<4\> Failed to create KML file C:/Program Files/Pix4Dmapper\bolaman\_mtps.kml.
[Error]: Cannot create OGR output file C:/Program Files/Pix4Dmapper\bolaman\_mtps.kml! ![](https://support.pix4d.com/hc/user_images/VTuoDI39M0TjiP-TgV0yDw.jpeg)
Difficult to tell why this error happens. Is there a pop-up window or is the error only displayed in the log file? Can you give more information on how you created all these tie points? and how you exported them? For the export I suppose you right-click on the “GCPs/MTPs” in the left sidebar, but to be sure. What would you like to do with the exported points?
Please share the entire log file through a file sharing service (Google Drive, Dropbox,…), maybe I can find something else there. If possible, also share the quality report of the project.
Lots of questions, but that should help to understand the case.
