Is it possible to add the .txt files containing the ground control points after running step 1? I know you can locate the ground control points on the map view rayCloud editor after step 1, so I would assume adding the .txt file after and not before step 1 would still be possible. I want to do this because I am running a batch of multiple projects and want to run step 1 first for all projects, add the GCPs after, then rerun the batch for step 2 and 3. Thanks in advance!
Hi Jonathan,
You can add and mark GCPs using the rayCloud after processing step 1. GCPs can be imported in .csv and .txt format. To learn more about it, follow the steps explained in our support article, How to mark GCPs in the rayCloud.
