Accuracy
I am flying a site that is approximately 290 acres. The client would like accuracy to be +/- 0.10’. When set up my flight plan within Pix4D capture it gives me a GSD of 1.09cm. The altitude will be 40 meters and I will have ground control points. I am using the DJI Phantom 4 Pro. Will I be able to achieve this accuracy? Any suggestions on ways that I can make adjustments to make this happen?
Not Really, but it is possible with technique and better rig. Which can chance cost of project greatly.
Give us a call if you have time for more suggestions. 3219694021
I may do that tomorrow. What company do you work for?
