hi guys
I processed a simple 3d model, but the processing of step 3 did not finish with this error:
“Warning w9020: GDAL error <1> DXF layer does not support arbitrary field creation, field ‘ID’ not created.”
I am not able to find references to this error code. What am I missing?
Regards
EDIT from Pix4D Support : we have changed the title from “Marius” to “Warning w9020: GDAL error <1> DXF layer does not support arbitrary field creation, field ‘ID’ not created.” so that it is more explicit what the post is about. Thank you for your understanding.
The message you copied, although it has the word error in it, is only a Warning message. Usually, warning messages from GDAL do not have any effect on the project, so I do not believe that this was the reason for the crash in the third step.
Could you give more information on your project? For example a quality report and log file? Maybe with a Google Drive or Dropbox link. That should help better understand the issue.
Thanks!
Pierangelo hi.
i have the Pahntom 4 Advance, I tried use the DJI GS PRO, but this app does not recognized my Drone. Can you help me please.
Best Regards.
@Datarock Ingenieria SAS: I would suggest using Pix4Dcapture instead. We have not tested the app with the Phantom 4 Advanced yet, so we cannot give any guarantees, but it should work if you select Phantom 4 Pro. More on that here: https://support.pix4d.com/hc/en-us/articles/203991609–Android-iOS-Which-drones-are-supported-by-the-app-#label1
For the future, please create another post by clicking “+New post” at the top of the Community for questions that are unrelated to the current post. Thank you.
