Please change the visualization of the Tin Surface back to the way it was in v1.39! It was so much easier to see when point cloud points were above the Tin Surface. In the later versions, the point cloud points are always shaded as though underneath the TIN until you navigate very close to the points in question, which makes it much more tedious to QA/QC the TIN from a distance. I much preferred the old visibility settings.
Thanks!
Dan
