This should be an easy solution, but I haven’t found it. When I need to fly a large area, I break it down into 2 or more flights. This leaves with with 2+ sets of pictures and 2+ data files.
The 2 picture files will have pics named the same, for example each pic set will have files named DCS0001, DCS0002, DCS0003 and so on.
Each data set will then have a set of coordinates for DSC0001, DCS0002 and so on.
Currently I go through and manually change each picture name in one data set to be DSC0001a, DCS0002a … Then I change the picture column of that data set to match.
This is super slow especially when I have many flights to combine. What is a faster way to deal with this issue?
