Looking for a sanity check. New to flying Mavic 3m… running my first mission with RGB+ms camera on a 160ac field… GSD of about 3.25cm/pxl… yielding about 110gb worth of mission data. Is this too large or is it in line? If it is too large, how might I look to curb the mission size? Any thoughts or commentary would be appreciated.
Hi Colin,
that sounds indeed a bit much. You can curb mission size by flying higher and by reducing the overlap settings. You can try with 70% sidelap and 75% frontlap.
