I have a area that has both roads and high elevated grass in it (30-60 cm)
Is there a way that i can offcet, and slam down the model but only where the grass is.
If It’s possible, how do i do this?
Hi Peter,
Could you take a screenshot of your model so we can see it?
It would be also very important to check your Quality Report. Could you upload it here? ![]()
Best!
Vag5MASEMYRX_report.pdf (893.1 KB)
Hi Peter,
If the point of your interest is the 3D Textured Mesh and you would like to smooth the grass, I would suggest point cloud classification. Using this method, you can assign the high grass to the disabled category leaving only the lower grass on the ground that will be visible in the model.
Learn more in how to generate the point cloud classification and how to edit the point cloud in the rayCloud.
Best!
