¿How to configure a camera in the Pix4D software, that is compatible with a Greenvalley X3 H LIDAR sensor, in order to use the photos it generates as input for photogrammetry? I appreciate the support you can provide.
Welcome to the Pix4D Community .
PIX4Dmapper has an extensive internal camera database but can process images from any camera model (RGB, multispectral, thermal). For cameras that do not exist in PIX4Dmapper’s camera database, the optimal internal camera parameters can be computed in the software while processing a good dataset.
For more information:
Note: You won’t be able to process LIDAR data in PIX4Dmapper.
Let me know if this helps.
Daniele
