My question is : are the orthoplanes geolocated when exported in TIFF like the orthophoto ?
I mean while importing them into Autocad can I use the command GEOREFIMG to force it to be 1/1 then mesureable ?
Thank you in advance
Kind regards
Dominique
Hello Dominique,
The Orhoplanes are not geolocated; they are in an arbitrary coordinate system.
If there is image geolocation and/or GCPs in the project, the scale will be correct, but the coordinates will be in the arbitrary coordinate system.
