From what I can tell, the M3M is collecting MSI data in a 16 unsigned integer format. The output from Pix4D fields is in a float32 format with typically the min and max values for different bands somewhere between 0 and 0.05. Is this correct? I was expecting the min and max to be 0 and 1. This is the how we are getting the outputs when stitching data collected with Micasense Altum.
Thanks.
