Matrice 210 + Rededge M + Pix4D capture integration
Good afternoon,
Here in our company we are about to buy a matrice 210 drone plus a multiespectral camera. Origanly we would tarjet the Rededge M as it appears to have better specs than the Sequoia for our research goals.
We have noticed that you have realesed the Pix4D capture for matrice 210 but we are wondering if it is possible to run without having another camera on board (just the multiespectral). And if so, have you move anyforward in triggering the capture of the camera from the Pix4D sofware itself or should we use the automatic internal trigger?
Thank you for your time.
Juan
Regarding Non-DJI cameras, on the iOS version of Pix4Dcapture you can select the custom camerasetting and as long as you have a way to set the RedEdge to capture images (time-lapse mode), you will be able to use it.
