KEYPOINTS GETTING MISMATCHED
Dear community,
this is heavy dense vegetation area,
altitude : 50m
overlap : 85
sidelap : 80
instead of matching with correct place and keypoints , the data has been overlaid in the other place
there is no problem in capturing
can anyone just tell me how to solve this issue
  • SDK
Hi @dinesh.selvamoorthy,
Can you please send your quality report for this project?
William
14MAY_JARA1_01_50M_report.pdf (3.3 MB)
hi william,
i have attached the quality report,
thanks for the reply.
-DINESH
I’m looking forward to seeing responses to this issue as well. I am seeing similar in some subprojects of a very large data set I’m working on now.
Thanks in advance!
Hi Dinesh,
Thank you for sending the quality report.
The following steps will generally create a better result for areas of dense vegetation in your model.
  1. Select the Ag RGB template.
  2. Change your Keypoints Image Scale to 1/2 under Custom .
  3. Keep the Internal Parameters Optimization at All . This setting is typically only changed if there was an issue in the previous set of results of step 1.
  4. You can find more information in this article: How to improve the outputs of dense vegetation areas using Pix4Dmapper?
William
​William Hawkins | Technical Trainer
