Hi all,
After doing initial processing, the quality report showed that my data passed all the quality checks EXCEPT matching which is flagged with a Red Triangle. Per pix4D instructions, I scrolled down to figure 5 to check which areas had weak matches but the figure shows strong matches everywhere (dark links instead of bright links). Does anyone know why my data is failing its matching quality check? Thanks. Attached is my quality report.
PixProject_191002_Huntington_11-1_report.pdf (981.1 KB)
