Hi, I want to improve the accuracy of point’s coordinates (specially in the z axis).
Problem: When I compare the same location for two different flights, the difference in the z coordinate is ~ 0.4 - 1 m.
Context: I’m trying to calculate the cut/fill of earthworks.
My procedure: Using pix4d Capture, I do 2 missions at different times (details in the images).
Then, I open the project in Pix4d Mapper and for each mission, I produce a DTM (details at images):
Then, I export both .dxf files to Civil3D and generate surfaces with the contour levels. However, I’m getting differences of ~1m of elevation at the same point. I want the error to be ~10 cm.
How can I improve the accuraccy?
Thanks in advance. If you need more info, just tell me.
