I have a project with PPK tagged images in WGS84/Ellipsoidal height. I also have GCPs that were collected and processed through OPUS and compiled into a .csv with both ellipsoidal height as well as a column for orthometric height. My question is, can I use those GCPs and have the output data have the elevations in NAVD88, rather than in ellipsoidal? How do I need to set up the image CRS, the project CRS, and the GCP CRS in order to make this work? I work for the Government and we have to have the vertical values in orthometric height (NAVD88). I originally setup the image CRS from the defaults from the WingtraOne camera (WGS84 w/ellipsoid height over the WGS84 ellipsoid) and set the GCP CRS to WGS84 w/NAV88 us feet for the vertical along with Geoid 18 (shown on the OPUS results). The actual GCP .csv I uploaded was referencing the Elipsoid Height field…because it did not want to accept the .csv with the orthometric field used. I also set the display units at the bottom of Matic to US Survey Feet and after marking GCPs and re-optimizing, I yielded the below results. Can someone please help?!
Camera SONY_DSCRX1RM2_35.0_7952x5304
Average GSD 0.088 ftUS
Project CRS WGS 84 / UTM zone 15N + NAVD88 height (ftUS) - EPSG:32615+6360 [GEOID18]
Quality check
Matches Median of 12347 matches per calibrated image
Dataset 99.91% calibrated (24619/24641), 1 block
Camera optimization 0.16% relative difference between initial and optimized internal camera parameters
GCPs 21 GCPs, Mean RMS position error 0.395 ftUS / Sigma 0.390
The GCP position error is more than 2.5 times the average GSD.
Checkpoints 0 Checkpoints
MTPs 0 MTPs
aITPs 0 aITPs
mITPs 0 mITPs
ATPs 107692662 ATPs
