I have the right geometry and also more than enough ground control points, is there a reason why elevation from point cloud is not checking with the actual ground elevation? The point cloud elevation is always higher.
Hey John,
Can you share some screenshots and the Quality Report of your project?
Did you reoptimize after marking the GCPs?
