I noticed that the vertical coordinate system of the images is set to EGM96, can you change it to Ellipsoidal?
Another suggestion is to process with 1/2 Image scale. May I ask if the problem is on the vertical or the horizontal?
-What is the coordinate system assigned to the Civil3D project? (command: CSASSIGN)
-Is the .2 consistent accross the whole project, other than the corner that’s 2 ft off?
-Do you have a .prj file for the field data? Most surveyors that I work with are using NAD83(2011). I noticed that yours is set to just NAD83. The .prj should also include the vertical coordinate system that survey used. That could be part of the issue.
There are programs (I use Global Mapper) that allow you to adjust the elevation of an entire dataset by whatever you want. Let me know if I can help with that in any way.
